Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
Hey car enthusiasts, where's the rear window glass lift switch in the Sequoia?
How to deal with water leakage from the rear spray nozzle of Jimny?
22,000 kilometers. When I went back home for the New Year on bumpy roads, I noticed a creaking sound when turning. Has anyone else experienced this issue? I have no idea where the problem might be. When I press down on the rear trunk, it doesn't make the sound, only when driving and turning. Sigh.
4Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
5Can the rear seats be folded down? Where can I adjust the height of the driver's seat?
6What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
7When the car's rear window glass closes to the top and then immediately slides down, what could be the issue?
