حسن مكرم
2024-04-08 20:48
When the MG ZS 2018 model reaches a speed of 90 km/h, there's a rattling noise from the rear. If the speed is below 90 km/h, the noise disappears. It sounds like an unsecured wiring harness inside the car, making a "da da da" noise. There are no noises when going over bumps or speed humps. I initially thought it was an issue with the right rear (passenger side) taillight assembly, but even after replacing it, the noise persists. I really have no idea where the noise is coming from now. Has anyone else experienced the same issue?
حافظ عبد العزيز
حافظ عبد العزيز2024-04-08 22:16
Check if the wheel arch liners are loose or cracked.
The car feels unstable at 90 km/h, how can I fix it?
How can I remove the 120 km/h speed limit?
When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
When driving at 60-80 km/h, I hear a buzzing noise coming from the front of the car. It gets a bit better when I speed up. I initially thought it was a bearing issue, but after replacing it, the noise is still there. What could be the cause? Could it be the belt, transmission, or something else? (The car has 130,000 km on it.)
When driving at speeds between 80 and 90 km/h, the car's chassis vibrates, but it becomes smooth again at speeds of 100 km/h. What could be the reason for this?
Has anyone experienced noise at 120 km/h with the 2013 4WD flagship model? It sounds like it's coming from the rear of the vehicle.
When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
Does anyone else feel a strange noise from the roof of their GWM Tank when driving at speeds of 170 km/h or more?
Loud noise at 100-120 km/h.
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
