طه سلمان
2023-12-16 06:56
When the car's steering angle exceeds 100 degrees, the chassis sometimes makes a "ka-ka" sound. What's the issue? It happens occasionally.
عبدالله سا مرعي
عبدالله سا مرعي2024-02-16 17:49
When you slowly release the brake after stepping on it, there might still be a noise, right?
عمر معاوية
عمر معاوية2023-12-16 07:05
Many cars are like this. Try not to turn the steering wheel all the way; leave a little gap.
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Do any of you have issues with the exhaust making occasional popping sounds? Mine is a 2019 model with 80,000 km.
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
