When buying a car air pump, why differentiate between single-cylinder and double-cylinder? Is the MG ZS single-cylinder or double-cylinder?
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
There is a gasoline smell entering the cabin of the MG ZS, especially when starting the engine. What could be the issue?
4MG ZS has run over 30,000 kilometers and is experiencing exhaust pipe issues, misfires in cylinders one to four, and unstable idling. Is this an internal engine problem? Is it very serious? Kind of regretting buying an MG. Went to the 4S dealership today for after-sales service, and the problem is still being addressed [frustrated].
5How did you guys solve the fuel pump belt issue of the 2017 MG ZS?
6I am sincerely asking for advice from everyone: When buying Subaru oil filters, air filters, and cabin air filters online, which specifications are the same between Subaru Impreza, Forester, and Outback?
7Is the oil pump on the MG ZS belt-driven? Has anyone experienced a belt break and replacement?
8When I turn the steering wheel of my MG ZS, I hear a clicking noise and feel vibrations under my feet. What could be the cause of this?
9For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
10How to choose between the MG ZS and the Geely Boyue?
