سعود أسماء
2024-08-25 09:24
The accelerator feels weak, and the control arm is making a rattling noise.
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
Is there a rattling noise from the chassis when accelerating with the H7? Has anyone experienced the same issue?
There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
Requirements for the front lower control arm.
How many control arms are there on the right rear suspension of the 2018 Hongqi H7 if the control arm and lower arm are bent?
Is it normal for the MG ZS to have sluggish acceleration and a rattling noise from the engine?
A car from March 2024, there's a rattling sound on concrete roads. The trunk makes noise, the center console island makes noise, and the seats make noise. It feels like the whole car is rattling.
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
