عمر مدرسي
2024-07-03 11:01
My 2019 MG ZS 1.5L automatic jerks when accelerating, and sometimes the check engine light comes on. After stopping for a while, the light goes off. It starts happening once the speed hits 40 km/h. What could be the issue?
سعود ميثا
سعود ميثا2024-07-04 19:04
I've experienced that too. Around 80 km/h, it stuttered a bit. Changed the spark plugs and it got better.
Hey folks, has anyone experienced their V40 shaking at speeds between 100 to 120 km/h, but then it stops shaking once it hits 150 km/h? I have an 18 model T5 with 55,200 km on it.
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
How do you reset the maintenance light on a 2017 MG ZS?
Does upgrading the system at a 4S dealership help with the jerking issues of the MG ZS 2020 model's transmission?
Looking for help, how do I turn on the fog lights on the MG ZS? And where do I activate the external circulation?
Does anyone know how to remove the rear tail light of the MG ZS? Thanks a lot!
My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
How to handle the occasional engine warning light in the 2020 MG ZS?
My 2018 automatic ZS sometimes shakes when waiting at a red light after the vehicle warms up. Between 60 to 100 km/h, the car feels like it's being pulled back, and there's a strong jerking sensation. If I press the accelerator hard to over 3000 RPM, the jerking stops. Using cruise control to accelerate also avoids the shaking. Is this a transmission issue?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
