أحمد طه
أحمد طه
Aug 24
My 2018 automatic ZS sometimes shakes when waiting at a red light after the vehicle warms up. Between 60 to 100 km/h, the car feels like it's being pulled back, and there's a strong jerking sensation. If I press the accelerator hard to over 3000 RPM, the jerking stops. Using cruise control to accelerate also avoids the shaking. Is this a transmission issue?
صدام محمد
صدام محمد2024-10-11 15:00
After replacing the spark plugs, everything was fine.
خالد سلطان
خالد سلطان2024-08-29 10:17
Have you changed the spark plugs? If not, get them replaced. I've changed everything else except the transmission oil.
نايف نوري
نايف نوري2024-08-27 15:13
As long as it can move and there's no abnormal noise, it's fine. This is a power issue, so there's no need to worry unnecessarily. The more you think about it, the more problems you'll imagine. If you just let it be, it might actually be better. Don't let it get to you.
I want to ask fellow car enthusiasts, what could be the cause of a jerking sensation when pressing the accelerator?
Is it normal for the Jeep Wrangler to have strong jerking sensations when starting right after warming up?
Does anyone know why the Volvo V40 T3 version feels weak during acceleration around 60 mph, and why the steering wheel shakes when lightly pressing the accelerator?
Hello everyone, I have a question about my 2013 Skoda Rapid. It's been driven over 70,000 kilometers. Currently, when I press the accelerator above 60 km/h, I feel like the front wheels are shaking with the throttle. Has anyone experienced this? What's the issue here? I went for maintenance, but they couldn't identify the problem. They mentioned it might be the driveshaft. Has anyone had a similar issue? How did you resolve it?
What causes a jerking sensation when gently pressing the accelerator?
My 2019 MG ZS 1.5L automatic jerks when accelerating, and sometimes the check engine light comes on. After stopping for a while, the light goes off. It starts happening once the speed hits 40 km/h. What could be the issue?
Does your Chery have a jerking sensation when you accelerate or decelerate?
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
MG ZS
MG ZSKWD 3,999 ~ 6,487Gasoline & Petrol
