Is the oil pump on the MG ZS belt-driven? Has anyone experienced a belt break and replacement?
Hello everyone, has anyone replaced the power steering pump on a 207 due to noise? Is it actually a power steering pump issue?
Has anyone changed the spark plugs on a 2018 manual MG ZS? Which brand is better? Any recommendations?
Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
4When buying a car air pump, why differentiate between single-cylinder and double-cylinder? Is the MG ZS single-cylinder or double-cylinder?
5How did you guys solve the fuel pump belt issue of the 2017 MG ZS?
6Is the oil pump on the MG ZS belt-driven? Has anyone experienced a belt break and replacement?
7Does anyone know how to remove the rear tail light of the MG ZS? Thanks a lot!
8Has anyone changed the headlights on a 2019 MG ZS? Any recommendations, thanks!
9Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
10Does anyone know if the oil pump drive for the 2018 35P 1.6L is a belt or a chain? Thanks!
