نايف عبد الغفار
2024-01-29 00:06
Is the engine of the 2018 automatic model noisy while driving? Has anyone experienced something similar?
سلمان فاروق
سلمان فاروق2024-02-28 10:59
I almost shouted when I spoke to 120, otherwise they couldn't hear me.
20
عمر معاوية
عمر معاوية2024-02-03 14:46
The startup sound is loud for a little while, but once the RPM drops, it's fine. This is all normal.
عمر شعبان
عمر شعبان2024-02-02 16:56
Yes, especially when starting, it's really loud.
What could be the reason for the 2018 BMW X1 stalling automatically in Drive? Has anyone encountered this issue?
I want to ask if anyone else has experienced this with the 720S: sometimes when I start it, a fault message pops up, but after driving for a while, it disappears on its own. When I check, it says there's no issue. Has anyone else encountered a similar situation? [Shocked]
Has anyone experienced the engine warning light flashing and the vehicle shaking? It gets better after a while.
Has anyone experienced the transmission not shifting while driving the 2.0T model? Thank you.
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
Has anyone experienced their head-up display flickering while driving?
Has anyone experienced the car shutting off automatically while driving, and then it won't start? You can't shift gears, the car rolls by itself, and the engine warning light turns on automatically.
Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
