Is sunroof leaking and rear door handle not retracting a common issue?
Have you experienced any sunroof leaks with your Jeep Liberty? How did you resolve the issue?
Are there any X95 owners experiencing sunroof leaks?
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
4I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
5Do any of you have problems with sunroof leaks?
6How to handle fuel vapor leaks?
7Once the speed reaches 80, there's a lot of wind noise, and the doors feel like they're leaking air, but I can't find the exact spot. Is this a common issue or do the doors have a problem?
8Has the leather on your car's door handles peeled off? All four of my door handles have this issue.
9Is sunroof leaking and rear door handle not retracting a common issue?
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
