نايف ربيع
2024-01-07 12:27
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
فهد طب
فهد طب2024-01-15 22:17
You can switch to 'D' without pressing anything. For other gears, you need to press the brake pedal. That's how automatic transmissions work.
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
Hey folks, I have a question. My car can't shift gears. When the engine is off, the gear lever can move freely, but when the car is on, it's like something is blocking it, and it won't go into gear. It's a manual transmission, and I can't shift into any gear from 1 to 5 when the car is on. Does anyone know what the problem might be? Thanks 🙏🙏🙏🙏
Hi everyone, for the 2019 Hongqi H7, is it possible to move the gear lever button from the passenger side to the driver side?
My 10-year-old Honda City automatic car has noticeable shaking when I shift into reverse gear, but it's smooth in other gears. Can any expert comment on what might be the problem with my car?
Does anyone know what the W button next to the gear lever on the 2019 automatic model is for?
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
My wife bought an 18-year-old used car, and today I drove it for a few dozen kilometers. I have a habit of occasionally resting my hand on the gear shift. When I did that, I noticed an issue. When shifting from second to first gear, I felt a slight "ka-ta" sensation! The sound is very faint, and you probably wouldn't notice it without your hand on the gear shift. Is this indicating a problem?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
