How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
4I have a 2019 model car and after I activated and then deactivated the child lock on the rear right door, it can't be opened from the inside anymore, only from the outside. Has anyone experienced this? How did you solve it?
5Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
6The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
7Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
8Why won't the right door open suddenly? Is it the child lock? Where's the child lock switch?
9If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
10The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
