حسن هارون
2024-01-07 09:07
How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
عبد له حسين
عبد له حسين2024-05-03 23:18
I have the same issue. When I drive long distances, the same thing happens. I replaced the sensor last year, but it's still like this. I'm not dealing with it for now. When I went out on the 1st, the water temperature light was flashing, but it fixed itself yesterday afternoon.
20
عمر سيف
عمر سيف2024-02-17 05:57
My car just flashed [grinning face], I don't know how to fix it.
Has anyone experienced airbag malfunctions? How did you resolve it?
How do you read your water temperature gauge? I couldn't even find where the gauge is.
Has anyone had the engine warning light come on? How did you deal with it?
How do you check the water temperature on a 2010 Legacy Luxury Navigation Edition?
Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
Have you guys replaced your halogen headlights? It's really hard to see at night. What kind of lights did you switch to? How much RMB did you spend?
Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
