سعود ميثا
سعود ميثا
Nov 14
Hey guys, has anyone experienced a car door that won't open? How did you fix it, by replacing the lock actuator or the lock itself?
أحمد عرفات
أحمد عرفات2024-11-18 12:51
I changed the lock, but the back door still won't open from the inside.
Do you sometimes have trouble opening your car door? Has anyone else experienced this?
The reverse camera display is glitching. Has anyone experienced this and knows how to fix it? It's been checked and seems like it's not an issue with the camera itself. Urgent!
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
After replacing the battery in the Sharan, the electric door won't open. Looking for a way to reprogram it.
I have a 2019 model car and after I activated and then deactivated the child lock on the rear right door, it can't be opened from the inside anymore, only from the outside. Has anyone experienced this? How did you solve it?
My 2013 model's driver side door lock isn't locking. Is it a problem with the lock itself or the electronic control? Any fellow car enthusiasts facing the same issue? How did you resolve it?
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
Has anyone experienced the fast charging port opening by itself after parking and locking the car? I've noticed it happening three times already.
Why won't the right door open suddenly? Is it the child lock? Where's the child lock switch?
My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
MG ZS
MG ZSSAR 41,900 ~ 81,995Gasoline & Petrol
