عبدالرحمن فيصل
2024-11-01 09:15
Hey folks, I've heard that for models after 2018, the oil pump belt tends to break easily after 60,000 km, leading to major engine repairs. Has anyone driven high mileage without replacing it?
عبدالله عاطف
عبدالله عاطف2024-11-17 16:28
Design flaw
حسن نور الدين
حسن نور الدين2024-11-03 18:50
I have reached 70,000, and I still haven't changed it!
طه سلمان
طه سلمان2024-11-03 08:41
There is no such situation.
سلمان خلدون
سلمان خلدون2024-11-03 08:22
Don't believe it.
سعود ميثا
سعود ميثا2024-11-01 18:14
65,000 and still hasn't been replaced.
How's the 2011 1.4T manual used Touran? I've heard the piston rings tend to break. Anyone familiar with this issue?
Model X, 40,000 km. There's a consistent humming noise from the rear wheels while driving, most noticeable at speeds of 35-40 km/h. You can feel a slight vibration in the floor when sitting in the back seat. I've been to the dealership a couple of times for this, and the last time, the technician confirmed the noise. After checking, they said the half axles are fine and concluded it's due to tire aging. I've heard that 21-inch tires tend to wear unevenly and might need replacement around 40,000 km. The tires only have 40,000 km on them, and the tread still looks clear. Is this really possible?
I have a 2011 Smart W451, and there's a buzzing noise after starting the engine. Here's what's happening: when I start the engine, everything is normal for the first 2 seconds, but after that, a low-frequency buzzing sound begins. The noise seems to come from the rear of the engine, near the inside of the passenger side. There are no fault codes, and everything else like acceleration and speed is smooth with no issues. I recently changed the fuel pump and haven't finished a full tank yet. The noise inside the car seems to be coming from below the passenger seat but slightly forward. I've changed the engine mounts, and the alternator belt looks fine. Has anyone experienced the same issue? Any help would be appreciated.
Is there a spare part for this car's steering column? It tends to break easily.
Hey guys, when is the Levante getting a major update? I heard last year it would be this year, with the Grecale's interior. But foreign websites say that after the update, it will be an all-electric version.
Is the oil pump on the MG ZS belt-driven? Has anyone experienced a belt break and replacement?
Can I still consider getting a 3.6 from 2017 to 2023 after a few years? I really like this model but I'm not a fan of the new Cherokee design. Plus, there aren't many 3.6 models from 2017 onwards available in the market. Our family car still has about five to six years before it retires. I'm worried about buying it only to face major repairs. Can I still consider getting one with higher mileage by then?
My relative gave me a 2006 Peugeot automatic 1.6L 307. A few days ago, it was running low on fuel (almost to the red line), and the range showed there were 60km left. Suddenly, it made a "ka" sound and everything stopped, showing something about "gearbox." After turning it off and restarting, it was fine, and adding fuel prevented the issue from happening again. Should I get it checked? The mileage was over 60,000 when I got it, and now it's at 88,000. Seeking advice from the forum experts.
How is the stability of the 2.0T Nissan Altima? Does it drift easily, and is the fuel consumption particularly high? How about the stability of the three major components, and does it tend to have many issues?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
