Has anyone replaced the charcoal canister solenoid valve?
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
Has anyone here replaced the charcoal canister?
4Has anyone experienced issues with the transmission solenoid valve on the URV?
5Hi everyone, can anyone tell me where the carbon canister solenoid valve is located in the Territory? A picture would be great. Thanks!
6Where is the Kia Sportage's charcoal canister purge valve located?
7Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
8The solenoid valve keeps breaking. How's yours doing?
9For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
102016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
