حسين ابراهيم
2024-03-04 15:35
Does upgrading the system at a 4S dealership help with the jerking issues of the MG ZS 2020 model's transmission?
عبد له حسين
عبد له حسين2024-05-03 23:15
My 2018 manual transmission car has a noticeable jerk when shifting from first to second gear. Do any of you have the same issue?
Do I need to follow the dealership's requirements for the 2020 model with 40,000 km? Transmission oil?
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
Did the Oshan 4S dealership issue a modification notice?
The 2020 ZS manual transmission isn't shifting smoothly and feels a bit stiff. I'm not sure if this is a common issue or just an individual case.
Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
MG ZS has run over 30,000 kilometers and is experiencing exhaust pipe issues, misfires in cylinders one to four, and unstable idling. Is this an internal engine problem? Is it very serious? Kind of regretting buying an MG. Went to the 4S dealership today for after-sales service, and the problem is still being addressed [frustrated].
How do I upgrade the infotainment system on a 2020 Jetour X90?
How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
How to handle the occasional engine warning light in the 2020 MG ZS?
MG MG ZS
MG ZSAED 66,900 ~ 77,400Gasoline
