After recharging the battery and reinstalling it, the loudspeaker, wipers, and hazard lights are working, but the car won't start. What should I do?
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
4When you open the door of a Sportage, do the hazard lights flash?
54WD light is flashing, and the vehicle won't start.
6How's your car battery? Mine won't start after sitting for three days. Any advice?
7After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
8What should I do if my ES300h's battery is dead after being parked for half a month?
9The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
10The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
