1.8L 2017 automatic luxury model with just over 50,000 km on the odometer. It's a red car with quite a few scratches on the exterior. It had a front-end accident but only needed a front set replacement, no damage to the frame. The right rear door has some bodywork done. However, the engine, transmission, air conditioning, and car system are all in excellent condition. You can test it out before deciding. It's a great choice for practice driving.
The Toyota Prius engine is typically located in the front of the vehicle. Here are some basic details: - The Prius is a hybrid car, which means it combines a gasoline engine with an electric motor. - The gasoline engine is usually a 1.8-liter 4-cylinder engine. - It is known for its excellent fuel economy (Fuel economy), making it a popular choice for those looking to save on fuel costs. - The hybrid system allows the car to switch between the gasoline engine and electric motor, or use both, to optimize efficiency and performance. If you need more detailed specifications or specific model year information, you might want to check Toyota's official resources or a trusted automotive website.
Looking to buy a 2015 model with a 4.2L engine Phaeton. Requirements: no accidents, good exterior and interior condition.
This is a description for a vehicle condition: It should not have been involved in a major accident or been waterlogged. The original engine is guaranteed. It's best if the structure is intact, and the frame should not have been altered.
4When buying a 2008 Yaris, here are some areas you should check: 1. **Exterior and Interior Condition**: Inspect for any signs of rust, dents, or scratches on the exterior. Check the interior for wear and tear, especially the seats, dashboard, and electronics. 2. **Engine and Transmission**: Listen for any unusual noises from the engine and ensure that the transmission shifts smoothly. Look for any leaks or corrosion. 3. **Brakes and Tires**: Check the condition of the brakes and ensure the tires have sufficient tread and are evenly worn. 4. **Suspension and Steering**: Test the suspension and steering for any unusual noises or stiffness. 5. **Electrical Systems**: Make sure all lights, indicators, and other electrical components are functioning properly. 6. **Service History**: Review the vehicle’s service history to ensure it has been well-maintained. After purchasing the car, here are some maintenance tips: 1. **Oil Change**: Start with an oil and oil filter change if it’s not recently done. 2. **Replace Air Filters**: Check and replace both the engine and cabin air filters if necessary. 3. **Check Fluids**: Ensure that all fluids (coolant, brake fluid, transmission fluid, etc.) are topped up and in good condition. 4. **Inspect Belts and Hoses**: Look for any signs of wear and replace if needed. 5. **Battery Check**: Ensure the battery is in good condition and clean the terminals if there is any corrosion. 6. **Spark Plugs**: Consider replacing the spark plugs if they haven’t been changed recently. 7. **Tire Maintenance**: Rotate the tires and check wheel alignment. By taking these steps, you’ll help ensure that your Yaris remains reliable and performs well.
5If you're trying to decide between the Mercedes-Benz E300L and the Porsche 718, both are great options but serve different needs. The Mercedes-Benz E300L is known for its comfort, luxury, and spacious interior, making it a good choice for long highway drives, especially if you need to carry passengers or luggage. On the other hand, the Porsche 718 is a sports car, offering a thrilling driving experience with its performance and handling, but it might not be as practical for daily commuting or long trips with more than one passenger. As a student needing to drive on the highway to school, consider what aspects are most important to you: comfort and practicality, or sporty driving dynamics.
6If you're looking for an SUV around 130,000 RMB for daily family use, Chery Tiggo 8, Jetour X90, and Haval Big Dog are all decent options. Here's a brief overview to help you decide: 1. **Chery Tiggo 8**: Known for its spacious interior and good value for money. It's a solid choice if you prioritize comfort and practicality. 2. **Jetour X90**: Offers a roomy cabin with flexible seating arrangements, making it great for family trips. It's also equipped with a range of features for convenience. 3. **Haval Big Dog**: Stands out with its unique design and off-road capabilities. If you enjoy a rugged look and some adventure, this might be the one for you. Consider what features are most important for your daily needs, like interior space, tech features, or off-road capabilities, to make the best choice.
7Hello everyone, I'm personally a big fan of the 2017 BRZ, but I haven't been able to find one in good condition. Today, I got contacted about a 2020 model, which only has two scratches exposing the primer on the bottom of the front bumper, with no other dents or marks. Now I'm hesitating whether to keep waiting for my ideal 2017 model or go for this 2020 model in good condition.
81.8L 2017 automatic luxury model with just over 50,000 km on the odometer. It's a red car with quite a few scratches on the exterior. It had a front-end accident but only needed a front set replacement, no damage to the frame. The right rear door has some bodywork done. However, the engine, transmission, air conditioning, and car system are all in excellent condition. You can test it out before deciding. It's a great choice for practice driving.
