علي عبد الرحمن
2023-07-03 23:18
When driving at low speeds and turning the steering wheel, the 2014 XV experiences significant body vibration and loud noise. However, this issue does not occur when the car is cold and has just started. I want to know what the reason could be? Does anyone else have the same situation?
سلمان له
سلمان له2023-07-07 19:47
Is it a noise from the steering gear?
Hey car enthusiasts, does your S40 make a really loud noise when starting the engine cold?
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
Hey folks, does anyone with a Multivan experience this? When starting from a cold engine, there's a huge vibration coming from the rear. The noise is really loud, but it goes away once the RPM drops. Does anyone know what's going on?
The car experiences significant body roll when cornering. I'm considering adding an anti-roll bar. Has anyone installed an anti-roll bar? Any recommendations? Thanks.
When driving at low speeds with the AC on, the car, which has over 30,000 kilometers, experiences significant vibrations. This is particularly noticeable when frequently reversing or making turns. The steering wheel, door handle, and seats all vibrate. Everything is normal when the AC is off. Sometimes, when idling with the AC on, there's a loud buzzing sound that feels overwhelming to the ears and head! I always use 95-octane fuel. Have you encountered this issue? How should it be addressed?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
What are the noticeable differences when driving the X-Bow and the 2.0 XV? Are there significant differences when off-roading for fun?
During driving, the 2016 Peugeot 301 makes a loud scraping noise from the undercarriage. It happens once every few miles. Sometimes it occurs when turning or braking, but most of the time it's quiet. What could be the issue?
Subaru Subaru XV
Subaru XVAED 83,990Gasoline
