عبد العزيز حارثي
2022-06-19 19:13
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
عبدالله جل
عبدالله جل2023-10-16 19:09
When the speed drops to 100 and then returns to normal, it might indicate that the oil pressure is insufficient while driving at high speed. If this makes you uncomfortable, consider keeping a bottle of oil in the car.
نايف يعقوب
نايف يعقوب2023-09-24 20:15
My 2013 model's oil light came on after 3,000 km. I added a liter of oil to fix it. Better keep an extra bottle on hand while on the road. [666][666]
سعود شجاع
سعود شجاع2022-07-13 01:17
Mine is also a 2012 model with 160,000 kilometers. When driving on the highway at 120 km/h for a long time, the light comes on, but if I drive at 100 km/h for a while, it goes off. Sometimes I add half a bottle.
عبد العزيز كمال
عبد العزيز كمال2022-06-21 16:11
If it doesn't burn much, just carry a bottle of engine oil and top it off occasionally.
فهد حسن
فهد حسن2022-06-20 13:02
Looking for a repair shop... Everyone can see when this thing is burning oil, but how to fix it, it's better to ask a professional... Sometimes it's just a carbon buildup issue...
Recently, my engine light came on. I went to the shop to reset it, but it came back on, indicating "Please check the emission system." Can any expert advise?
Is there anyone who has replaced the 2012 XV's dashboard with the 2016 high-end version? Any recommendations?
Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
Does your car have a rattling noise in the timing belt area? I went to the 4S shop and they said it's nothing. 🤥🤥🤥
My car is over three years old, and it's really sluggish when I try to accelerate. I went to the repair shop, and they said there's an issue with my transmission. Fixing it would cost quite a bit. Has anyone else experienced this? How should I deal with it? Thanks, everyone!
Subaru Subaru XV
Subaru XVAED 83,990Gasoline
