The mechanic said my radiator is leaking, but I haven't noticed any decrease in the coolant reservoir, and there haven't been any warnings on the dashboard. Should I replace the radiator now? Thanks for any advice!
I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
Has any car owner modified the headlights? I asked at the shop and they said it needs to be changed to 16 lenses, 8 for low beam and 16 for high beam. I haven't seen any examples of such work, so I didn't dare to modify it easily. [Facepalm]
4My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
5In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
6Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
7The dashboard is indicating a daytime running light malfunction, but I haven't noticed anything wrong. The daytime running lights are functioning properly.
8I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
9I'm seeking advice from experienced Scirocco owners. I have a 2012 2.0T Scirocco, and every time I accelerate a bit harder and the RPM goes higher, the EPC warning light comes on. I went to a mechanic before, and they just cleared the code, saying it was nothing serious. But recently, it’s happening more frequently. Can any experienced drivers explain what's going on? Thanks!
10Has anyone used cruise control on the luxury edition? I haven't used it before. I tried it on the highway, but it didn't respond. Am I doing something wrong? Any advice would be appreciated.
