If both the person and the key are inside the car, does the electronic anti-theft indicator on the dashboard still flash normally?
If the car is already started, you can usually drive it even if the key is not inside. However, most modern cars will give a warning sound or display a message indicating that the key is not in the vehicle. This is to alert the driver that the key might be missing. As a chauffeur, if you reach the destination and the owner cannot find the key, it's important to inform them about the situation.
4I recently took my 2021 manual 1.6 35p to the dealership to replace the clutch pedal. After coming back, I noticed that when I lock the car, the indicator lights flash rapidly six or seven times. Previously, they would flash slowly twice. Additionally, there's a warning about low key battery, but the key can still control the car from a distance. What's going on?
5Does the Peugeot 3008's automatic door lock still allow the doors to be opened from the inside? Is this normal? What solutions are there? Otherwise, it really doesn't feel secure.
6Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
7Can you lock the car if both the person and the car key are inside?
8The dashboard shows that the electronic key is not inside the car, but the key is inside. How to solve this issue?
9The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
10Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
