I'm an owner of a 2012 XV and haven't really been to the dealership much. A few days ago, I went to get a small part replaced, and the manager mentioned that there's a recall for this model. It requires replacing the valve springs and brake switch, but it seems too troublesome since it needs the engine to be taken out, so I didn't do it. Has anyone else gone through this? If I don't do it, will there be any impact?
I heard that this car was previously recalled to the 4S shop for replacing the airbag inflator, or perhaps the airbag itself. Is that the case?
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
4I want to replace the spark plugs myself, but I'm not sure where they are located. How do I replace them?
5Hello everyone! For those who have bought a Maserati Grecale and registered it, I'm planning to pick up my Grecale in a few days. I want to ask if the Grecale needs to go through the inspection line at the vehicle management office? Thanks!
6Hey guys, the dust boot on the control arm ball joint is torn. Is it necessary to replace it? Will it have a big impact if I don't?
7For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
8How do I replace the headlight bulb on a Sharan?
9What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
10Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
