Has any xV owner experienced the issue of not being able to remove the key after the engine is turned off? How did you solve it?
Is anyone experiencing unstable idling with their car? How did you solve it?
Did the Adventure and Off-Road versions start being sold from the 2020 models?
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
4Has any xV owner experienced the issue of not being able to remove the key after the engine is turned off? How did you solve it?
5I've got a 2012 XV and while driving, the hill assist light turns on, then goes off, and comes back on again. Does anyone know what might be causing this? Has any fellow driver experienced this and how did you resolve it?
6Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
7Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
8The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
9Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
10Hey guys, does your infotainment system show no network and data being stolen by aliens? How did you solve it? Thanks, everyone.
