Good morning, has any owner experienced the situation where the car doesn't move without accelerating after the annual inspection, and the fuel consumption increases? What could be the reason for this?
What could be the reason for a Haima S5, 2016 model Enjoy Edition, not moving after shifting gears without accelerating?
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
4The 2017 Land Cruiser with an automatic transmission struggles to accelerate when flooring the gas pedal, with the RPM not going above 2300, causing slow acceleration. However, when using cruise control, the acceleration is faster, and the RPM can increase. What might be the reason for this?
5Fellow Territory S owners, have you experienced a situation where the dashboard shows a message saying the transmission needs maintenance, and when you accelerate, the RPM increases but there's no power?
6Hey car enthusiasts! For the 2017 MG GS 30T, if you're finding that the car lacks power when starting without using the accelerator, what could be the reason?
7I was thinking about getting it back then but didn't make a move. What's the situation now? Is it still a good idea to get it, or is there a risk of it failing?
8Hey fellow Grand Cherokee owners, when I start my car in the morning, I hear a "clattering" sound from under the chassis, but it goes away after starting. What could be the reason for this?
9Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
10Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
