Do your car's wheel bearings break easily? I just replaced them 3,000 kilometers ago and they're broken again. Is this a common issue with this car model, or could it be caused by something else?
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
After reaching a speed of 60, there is a constant hissing sound from the right rear side in my Arrizo 3. Is this due to wind resistance caused by a design issue, or could it be something else? Has anyone else experienced this problem?
4Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
5Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
6When driving at 60-80 km/h, I hear a buzzing noise coming from the front of the car. It gets a bit better when I speed up. I initially thought it was a bearing issue, but after replacing it, the noise is still there. What could be the cause? Could it be the belt, transmission, or something else? (The car has 130,000 km on it.)
7The rear tail light on the driver's side doesn't light up when I brake. I just replaced the bulb half a month ago, and now it's not lighting up again. The previous inspection said it wasn't a bulb issue. Has anyone else experienced this? What's the problem?
8My relative gave me a 2006 Peugeot automatic 1.6L 307. A few days ago, it was running low on fuel (almost to the red line), and the range showed there were 60km left. Suddenly, it made a "ka" sound and everything stopped, showing something about "gearbox." After turning it off and restarting, it was fine, and adding fuel prevented the issue from happening again. Should I get it checked? The mileage was over 60,000 when I got it, and now it's at 88,000. Seeking advice from the forum experts.
9In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
10What should I do if the touchscreen stops working? The dealership said it's a common issue, and since it's out of warranty, they suggested I replace it myself (which is quite honest of them). Has anyone else encountered this problem? Which type of screen is suitable to replace it with? 😊
