Do I need to remove the oil pan to change the oil?
Do I need to change the transmission oil for a 2016 Skoda Rapid, automatic, 6-speed?
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
4Do I need to remove the oil pan to change the oil?
5Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
6Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
7Do I need to change the transmission oil for a 2019 GAC GS5 Elite version with 70,000 kilometers on it?
8Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
9Why is it indicating that I need to change the oil again when I just changed it in March?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
