سلمان حاتم
2023-07-06 11:23
Whose car would behave like this, suddenly losing power while accelerating and then gaining speed again?
أيوب سلمان
أيوب سلمان2023-10-21 21:36
Hello, this is normal. In an automatic car, the gear shift will adjust based on how much you press the accelerator. For example, if you accelerate rapidly, the car will assume you want to speed up or overtake. At that moment, it will downshift to provide you with enough power for acceleration or overtaking. Once you finish accelerating, it will upshift, just like in a manual car where you need to downshift to speed up or overtake. Feel free to use it. I hope this helps you.
أحمد آدم
أحمد آدم2023-10-21 05:22
That's normal! When you suddenly accelerate, the transmission thinks you want to overtake, so it downshifts. Then, once the power is up, it shifts up again!
حسين كاظم
حسين كاظم2023-07-30 17:09
How much is it?
سلمان منذر
سلمان منذر2023-07-06 23:12
Hello, for the problem you've described, you can have it checked and handled at a nearby service station.
My car is a 3.0T manual, and when accelerating to a certain speed, it suddenly feels like it's slowing down. Can any expert explain why this might be happening?
Does anyone experience a situation where, while driving a manual transmission car at high speed, the RPM suddenly goes up but the speed remains the same?
Why does the Ford Territory suddenly lose power and then accelerate again multiple times when normally accelerating to 60 km/h?
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
2015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
Has anyone experienced their car's infotainment system suddenly losing internet connection?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
JETOUR Jetour X95
Jetour X95AED 132,000Gasoline & Petrol
