سلمان مستنصر
سلمان مستنصر
Aug 24
The battery of the JETOUR X95 is dead, and the remote key buttons are not working. After jump-starting the car, the emergency braking system activated. The car can drive normally, but the dashboard is only partially functional, as the idle speed and speed are not displayed. I tried to reprogram the keys because I have four keys, and the previously working key is not functioning anymore. However, I'm unable to successfully reprogram the key, and now the car won't start. Has anyone encountered this issue before? How was it resolved? This is the 2020 JETOUR X95 dual-clutch version.
Comments( 7 )
عمر شمس
عمر شمس2024-09-21 21:30
Try disconnecting the negative terminal. A couple of days ago, after jump-starting, all the driver assistance systems reported errors. Then, after restarting, the car's infotainment screen went black. Finally, disconnecting the power solved the problem.
حسين أمين
حسين أمين2024-09-21 16:30
After jump-starting the battery, there might be unusual issues with the dashboard. As for the situation you mentioned with the four keys showing up, it's best to visit the service station for a check and matching.
محمد تامر
محمد تامر2024-09-09 06:22
My car is also the 2020 model with 6 seats. I keep one key with the battery removed and set aside, while I regularly use the other one. So far, I haven't noticed any issues.
محمد تامر
محمد تامر2024-09-09 06:20
Why are there four keys? [I want to be alone]
عبدالرحمن جعفري
عبدالرحمن جعفري2024-09-03 18:46
Has your issue been resolved?
عبدالرحمن جعفري
عبدالرحمن جعفري2024-09-03 18:45
My car wouldn't start even after reconnecting the battery's negative terminal. The display screen next to it stayed on even when the door was closed and the car was off, so I disconnected the battery to cut power. Now, after reconnecting, the car still won't start.
عبدالله رضوان
عبدالله رضوان2024-08-27 10:44
It's time to change the car.
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
My HS's electronic start-stop function isn't working. Is there any solution?
Does the 2020 model of Jetour X70 have an automatic flashing function, like hazard lights, when braking hard at high speed?
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
The "Follow Me Home" function on the 2021 Jetour X90 headlights is not working. When you lock the car doors, the headlights do not turn on.
2022 HONGQI HS7 QiChang with five seats, driven 8000 miles. After rain, the keyless entry system failed. The key can only lock and unlock the doors; inside the car, the key is not recognized (both keys have this issue), and the car won't start (even emergency start doesn't work). HONGQI Smart Connection can start the vehicle, but it can't be driven away. The 4S shop inspection indicated a key matching fault, and after re-matching, it worked fine. However, the issue reoccurred 5 days later. What could be the problem? Have any fellow car enthusiasts experienced this? How do you deal with it?
If the remote control function of your Peugeot 307's key is not working, even though the key itself is in good condition, what could be the issue?
What could be the reasons for the Peugeot 3008's automatic start-stop function not working properly?
Hey car enthusiasts, does the rear trunk of the Seltos luxury edition have a remote control function? I see a trunk remote icon on the key fob, but it doesn't work. Thanks!
Jetour X95
Jetour X95AED 132,000Gasoline
