مك خالد
2023-08-18 10:41
Lately, I've noticed that when I start driving, the car stays in first gear until 2500 RPM and then suddenly shifts with a big jolt.
عبد العزيز بهاء
عبد العزيز بهاء2023-08-24 14:17
Dear car owner, I suggest you visit a service station to check the transmission software version. See if it can be upgraded or if the transmission clutch needs re-learning. Wish you a pleasant driving experience!
نايف ثاني
نايف ثاني2023-08-20 10:37
The problem isn't there, it's just slow response when accelerating [I want to be alone].
أحمد نور دين
أحمد نور دين2023-08-18 15:26
Normal phenomenon [I want to be alone]
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
Hello everyone, is it normal for my 2013 Mazda 5 automatic to have a noticeable jerk when shifting from first to second gear, while other gears aren't as obvious?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
JETOUR Jetour X95
Jetour X95AED 132,000Gasoline & Petrol
