avatar-image
عمر راضي
Mar 10
Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
محمد منصور
محمد منصور2024-11-14 16:24
CheZhiWang Complaint: My 2020 1.6 Explorer Edition also has this issue.
سلمان مستنصر
سلمان مستنصر2024-10-21 23:48
The electronic module of the transmission has an issue. When shifting from first to second gear, it takes over 3000 RPM to shift, right? And when it shifts, there's a double jerk, isn't there?
عبدالله أشرف
عبدالله أشرف2024-03-13 06:10
The transmission learns automatically based on your driving habits and terrain. The Qingshan transmission's intelligence isn't that great; you can think of it as the first generation that's not very smart. You can go to the shop and update the transmission software. After updating, try to drive gently on flat roads for a few days so it can learn. There's no solution for now.
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
I have a question for everyone. I have a 2009 Honda City automatic 1.5. There's some jerkiness when shifting from 1st to 2nd gear, but it's better from 2nd to 3rd. Since it's a used car, I'm not sure how many kilometers it's been driven. Can changing the transmission oil solve this issue? How many liters are needed for a gravity change of the transmission oil?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
Is there anyone experiencing a harsh jolt when shifting from 1st to 2nd gear, along with some strange noises? I'd like to ask for solutions. Mine is a 2019 X95. Thanks!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Jetour Jetour X95
Jetour X95AED 132,000Gasoline
