Is there anyone experiencing a harsh jolt when shifting from 1st to 2nd gear, along with some strange noises? I'd like to ask for solutions. Mine is a 2019 X95. Thanks!
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
I'd like to ask fellow car owners, when you turn off the car and park it in P gear, does it move slightly when you release the brake? Mine has been doing this a lot lately.
4I have a question for everyone. I have a 2009 Honda City automatic 1.5. There's some jerkiness when shifting from 1st to 2nd gear, but it's better from 2nd to 3rd. Since it's a used car, I'm not sure how many kilometers it's been driven. Can changing the transmission oil solve this issue? How many liters are needed for a gravity change of the transmission oil?
5Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
6Is there anyone experiencing a harsh jolt when shifting from 1st to 2nd gear, along with some strange noises? I'd like to ask for solutions. Mine is a 2019 X95. Thanks!
7Is there anyone who has experienced this situation? When shifting from 1st to 2nd gear, the car doesn't accelerate even though the RPM goes up. I have to release the accelerator and then press it again to make it work. What's going on here? Is it a transmission issue or something else? How did you guys solve it?
8MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
9Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
10Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
