I've only had my car for ten days, and it won't start. Checked the battery, and it's fine. Not sure what's wrong.
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
My Volvo S40's battery seems fine. Why does the electrical system show a fault, and it starts smoking as soon as I start it? We've checked but can't find what's wrong.
4It seems like the car key is out of battery, and the car won't start.
5How's your car battery? Mine won't start after sitting for three days. Any advice?
6Is there anyone else experiencing severe battery drain with their Hongqi H7? If I don't drive for four days, the car won't start due to significant battery loss.
7My 2009 Peugeot 307 won't start. When I try to start it, the engine doesn't respond, and there's just a buzzing sound. Does anyone know what could be wrong? The battery was replaced not long ago.
8Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
9I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
10In the past couple of months, I've experienced my car's system crashing twice. The first time, I had to disconnect the car battery and reset to factory settings to get it back to normal. But after about ten days, it happened again. This time, I didn't do anything, and after letting the car sit for an hour, it started working fine again. I'm not sure if it's a hardware or software issue, as I haven't updated the system for quite some time. Has anyone else experienced something similar?
