I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
4The 2023 standard version Rubicon has an issue where if it's left for two nights, the brake pedal becomes very hard in the morning when I press it to start the car. I'm wondering if anyone else has experienced this issue with their Jeep. I went to the 4S dealership, and they checked the vacuum pressure, which was at 620 and held for a morning without any signs of leakage. Is using a smoke machine the only way to check it? Sigh 😮💨
5After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
6I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
7Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
8If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
9Is the vibration noise when the wiper of the new ES200 reaches the far left side related to the glass oil film? Does anyone else have a similar issue?
10I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
