محمد نور دين
2022-09-30 15:11
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
عبدالرحمن أكبر
عبدالرحمن أكبر2022-10-25 12:06
I also experience cold air at first, but after a while, it starts to get hot, and the airflow is too weak.
نايف يسار
نايف يسار2022-10-05 22:41
You turned on the wrong switch.
عبدالله أشرف
عبدالله أشرف2022-10-04 06:29
Does this car have ventilation? The lower trim seems to not have it, right?
نايف رائد
نايف رائد2022-10-01 22:31
You've also turned on the seat heating.
Is it necessary to install side steps on the JETOUR X95? Thanks!
Hello everyone, just wanted to ask if anyone has rear axle parts for a 2013 SsangYong Korando? Thanks!
I want to upgrade the seat with ventilated massage lumbar support and queen seat. Will this affect my lifetime warranty???
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
Could anyone recommend a good seat ventilation cushion? It's so hot driving in the summer. How do you all deal with it?
The seat ventilation makes noise but doesn't blow air. The dealership said it might be the sponge slipping, and repairing it would require removing the seat and replacing the sponge, costing over 1000. Has anyone experienced a similar issue? How did you handle it?
Can the seats of the Supernova Pro be retrofitted with ventilation and an independent blower added for the rear air conditioning at the 4S dealership? It's too hot, and the air conditioning is really poor.
JETOUR Jetour X95
Jetour X95AED 132,000Gasoline & Petrol
