عمر راضي
2023-08-16 17:06
Hey car enthusiasts, have you ever experienced a jerky start, where you accelerate but the car doesn't move immediately, and then suddenly jumps forward after a few seconds?
Comments( 6 )
أحمد فواز
أحمد فواز2024-12-05 21:00
I had this issue at first too, but replacing the transmission carbon valve solved it. 🌹🌹🌹
محمد منصور
محمد منصور2024-11-16 23:02
2020 X95 model, experiencing significant jerking at 20-30 RPM. The car is lurching, how can this be resolved? The local 4S shop suggests changing the transmission oil and cleaning the throttle, but I feel like they're just brushing me off. Also, there's some play in the steering, and once the speed reaches 70, it feels like it's swaying left and right, requiring constant steering corrections. What could be the cause?
حسين بشار
حسين بشار2023-12-02 23:39
The same situation.
أحمد عبد القادر
أحمد عبد القادر2023-11-04 05:40
There's no such problem.
عبدالله أمين
عبدالله أمين2023-09-17 13:03
Just make do with it. Especially when the engine is cold, the RPM goes up suddenly, it feels like it could take off.
حسين عبد المجيد
حسين عبد المجيد2023-08-17 09:19
This car has a common issue! It's mainly a problem with the transmission! Over time, you'll get used to it.
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
Why does the car not move when I put it in gear, but only moves when I accelerate?
Hello fellow car enthusiasts, every time I refuel my Scirocco and then put it in Drive, it takes two or three seconds before the car moves forward. Is this normal? If not, what might be the problem?
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
Have you ever experienced the second generation MG6 occasionally requiring a second attempt to start? Are there any warning lights appearing? What is the situation?
Why does my car suddenly feel heavy while driving? It always feels like the brakes are on, and it won't move unless I press the accelerator hard...
Can the Eyesight cruise control automatically move forward after stopping? Why didn't my car move after the car in front of me started moving the other day?
JETOUR Jetour X95
Jetour X95AED 132,000Gasoline & Petrol
