سلمان حاتم
2022-11-01 15:30
After the discontinuation of the X95, what happens to parts and warranty? How do you handle repairs after the warranty period? Are the parts the same as other cars? Is there a design issue?
خالد حجاج
خالد حجاج2022-11-04 22:57
The grille and some exterior differences are notable, but other aspects are the same as the current GWM Poer model.
حسن عين
حسن عين2022-11-03 11:42
Even if a vehicle model is discontinued, the parts are still available, so maintenance and repairs are no problem. In fact, the costs might be a bit cheaper. As long as you do regular maintenance, the car won't break down.
مك خالد
مك خالد2022-11-02 15:03
The parts for this car should be quite compatible with the 90, right?
The design of the Hongqi E-HS9 is nice. If there were an extended-range version, its sales might increase. Other issues will likely receive feedback from car enthusiasts after they've driven it for six months.
I'm considering buying a used Jetour X95. I'm not sure about the warranty and other things I should pay attention to.
For a 2013 used Mitsubishi ASX 2.0 manual, it's said that the main components are imported. After purchase, aside from consumables like engine oil and brake parts, would other repairs be particularly expensive? Or should I just use aftermarket parts? I've driven company cars with 1.3L, 1.6L, 2.4L engines, front-wheel drive, rear-wheel drive, and manual transmissions.
What rights do we have if the car is left at the dealership for 35 days during the warranty period and still hasn't been repaired? It's so frustrating...
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
I've got a 2016 manual Vitara, and I've noticed marks on all four door screws. It's a used car, so I'm worried the doors might have been repaired. Do other owners have the same issue?
Has anyone encountered cracked door handles on a 20-year-old Cayenne? The 4S shop refuses to repair them under warranty because it's expired. What should I do?
If I don't maintain my car at the 4S store after the four-year or 100,000-kilometer free maintenance period, will it affect the lifetime warranty?
After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
JETOUR Jetour X95
Jetour X95AED 132,000Gasoline & Petrol
