عمر جبريل
عمر جبريل
Dec 16
Why do I have to manually activate the Lane Departure Warning every time I drive the 2020 Jetour X90 Yingyue model? After turning it on, if I turn off the engine and restart, I have to manually activate it again. Why is this happening?
Comments( 7 )
عبدالله علي
عبدالله علي2024-04-22 20:23
I also have a 90 model Yingyue, and I haven't encountered that issue.
سعود مستنصر
سعود مستنصر2024-04-17 23:07
Some features are turned off by default, and you need to enable them when you use them.
محمد عزيز
محمد عزيز2024-04-15 12:20
The lane departure warning system is turned off by default because there are options for lane assist types and lane departure warning sensitivity settings. So, the system is off by default!
أحمد محملة
أحمد محملة2023-12-18 19:30
Same here, every time I turn off the engine, I have to manually turn it on next time.
حسين عمار
حسين عمار2023-09-10 19:39
Did you solve this issue? Mine is the same now.
خالد كم
خالد كم2020-12-16 22:58
I want to ask where to open it. I haven't used it since I bought it. [cover face][cover face][facepalm][facepalm]
نبراس سلمان
نبراس سلمان2020-12-16 14:13
The lane departure warning system is turned off by default, so you have to manually activate it every time you drive. This feature is quite useful on highways.
Jetour X90
Jetour X90AED 89,000 ~ 115,000Gasoline
