What is the situation with the abnormal noise from the water pump of the Jetour X90 Wilderness Edition 1.6T? Is it normal?
What could cause high water temperature if the water pump and thermostat are not the issue?
Hello everyone! What's the specification for the water pump alternator belt for a 2008 Mazda 5?
Does the water pump for the 1.8 Yizhi from the 12th edition match with the one for the Corolla?
4Hey fellow car enthusiasts, what should I do in this situation? I've been to the 4S shop to update the software and replaced the water pump and fan, but the problem still exists. [crying][crying]
5What do you think about the Jetour X90 Kirin 1.6T?
6What is the situation with the abnormal noise from the water pump of the Jetour X90 Wilderness Edition 1.6T? Is it normal?
7What is the top speed of the Jetour X90?
8The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
9Does the Jetour X90 PLUS Villa 1.6T 2024 support automatic folding of the side mirrors when the engine is turned off?
10Why is the Baidu CarLife in the 2023 Jetour X90 Plus Villa edition only displaying on half the screen?
