The touchscreen on the 2022 GWM Cannon stopped working after pressing a button, and now it can only be operated using the knob.
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
Why does the dashboard keep displaying "Please check the start-stop system"? Does pressing the physical button have any effect?
4Are there any owners of the 2018 model using the original car navigation? I want to ask if the power and mute buttons on the left side of your original car navigation work. Why did mine stop working? The volume button on the right side works.
52020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
6In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
7I'm not sure what you pressed, but now the rear windows only go halfway down. 😢😢😢😢😢
8Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
9The touchscreen on the 2022 GWM Cannon stopped working after pressing a button, and now it can only be operated using the knob.
10Anyone else having issues with the automatic massage function not working? One day in August, it suddenly stopped functioning properly! I can only control it manually now... Speechless!
