The "Follow Me Home" function on the 2021 Jetour X90 headlights is not working. When you lock the car doors, the headlights do not turn on.
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
What could be the issue with the right rear door of a Jetour X70 not locking?
Where is the central door lock for the 2021 facelift of the KIA Pegas? Does anyone know?
4The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
5Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
6The "Follow Me Home" function on the 2021 Jetour X90 headlights is not working. When you lock the car doors, the headlights do not turn on.
7The 2021 VW Teramont's door suddenly became unresponsive to touch at night and couldn't be closed. The remote control works, but the touch feature is not functioning.
8Can anyone tell me if it's possible to turn off the lock beep on the X90plus?
9The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
10Does the Jetour X90 PLUS Villa 1.6T 2024 support automatic folding of the side mirrors when the engine is turned off?
