حسين جليل
2024-12-04 21:52
To start the 2024 Jetour X90 Plus with a manual transmission, you should: 1. Press the clutch pedal. 2. Press the start button. The start button may have three sets of English instructions, typically indicating different stages such as ACC (Accessory), ON (Ignition), and START. You just need to press the clutch and then press the start button to start the engine.
أحمد مروان
أحمد مروان2024-12-05 22:02
[666][Grinning] Start it however you want [I want to be alone]
خالد جعفر
خالد جعفر2024-12-05 17:44
You need to press the clutch to start the engine.
عبد العزيز خليف
عبد العزيز خليف2024-12-05 13:48
Why use the clutch when starting the car? Isn't it the brake that should be pressed to start? Also, whenever you see any warning signs, you should really take a photo. Otherwise, other car enthusiasts won't be able to help you analyze the issue. [I want to be alone]
حسين زكريا
حسين زكريا2024-12-05 09:08
Start the engine directly!
How do you start the ignition of a Volvo S40? The key looks like plastic. [shy]
The air conditioning filter for a 2013 Liana is typically located behind the glove compartment. You may need to remove or lower the glove compartment to access it.
Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
Why do you have to press the rear window button once before starting the 2013 GS5?
To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
Even with the clutch fully pressed, the car still won't start.
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
JETOUR Jetour X90 Plus
Jetour X90 PlusAED 119,000Gasoline
