نايف ياسر
2024-10-03 16:15
The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
نايف إدريسي
نايف إدريسي2024-10-24 12:01
I recently bought an X90 and the rear side doors won't open. Can any fellow car enthusiasts offer some guidance? Thanks!
حسين أمين
حسين أمين2024-10-24 08:29
Can't open it from the outside? Maybe you turned on the drive lock switch from the driver's seat, which prevents opening from the outside. If it can't be opened from the inside, check if there's a child lock switch on the side of the door. Did you turn on the child lock switch?
نايف جبريل
نايف جبريل2024-10-04 00:24
Did I accidentally lock it? [I need some peace]
During the rainy season, typically from April to August, the car doors cannot be opened from inside or outside, while they function normally at other times. Could it be that the lock mechanism is affected by moisture on rainy days? What might be the issue here? Experts, please help! Thank you!
I have a 2019 model car and after I activated and then deactivated the child lock on the rear right door, it can't be opened from the inside anymore, only from the outside. Has anyone experienced this? How did you solve it?
What is the situation with the abnormal noise from the water pump of the Jetour X90 Wilderness Edition 1.6T? Is it normal?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
I'd like to ask fellow car enthusiasts a question. For the 2020 4WD Elite Edition Jeep Compass, is there a button inside the car to open the trunk? I've been opening it from the outside directly for four years. Does anyone know?
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
Can you open the car door directly from the inside while driving, is it always like this?
The inner button on the passenger door isn't working, but it can be opened using the screen controls and from the outside. What could be the reason for this?
If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
JETOUR Jetour X90 Plus
Jetour X90 PlusAED 119,000Gasoline
