فهد ميك
فهد ميك
Nov 25
My new car makes a clicking sound and won't start, but if I turn it off and try again, it starts fine. Does anyone know what's going on?
عبد العزيز خليف
عبد العزيز خليف2024-12-05 14:15
It's likely that the battery is running low. Try not to keep the car off while listening to music inside. Additionally, the installed dashcam also consumes power.
عبدالرحمن سعيد
عبدالرحمن سعيد2024-11-26 10:13
Battery voltage is insufficient, recommend checking the battery.
The battery is new, and the car starts fine when it's cold. But after driving for about ten minutes, sometimes when I stop and try to restart, it makes a squeaking sound and won't start. If I turn it off and then gently start it again, it works. I'm asking if anyone knows what might be causing this issue and if anyone has experienced something similar?
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
How long does the Jetur X90 turn off after starting the car with the one-click start on the phone?
The dashboard lights keep staying on after turning off the engine recently, and I can't lock the car. Then, when trying to start again, it takes three or four tries to get it going. After starting, the dashboard lights come on again. When the dashboard lights are on, pressing the remote to lock the car doesn't work at all. Locking the car feels like a lottery every time.
The turn signal is intermittently malfunctioning. Most of the time, it fails when the headlights are turned on—there's no light or clicking sound. Once the headlights are turned off, it works fine again. Has anyone else experienced the same issue?
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
Jetour X90 Plus
Jetour X90 PlusBHD 9,137 ~ 12,586Gasoline & Petrol
