Is it normal to have watermarks inside the headlight cover?
Comments( 6 )
Where can I buy a replacement headlight cover if the casing is broken?
Is it normal for a 2009 Liana valve cover gasket to have oil seepage and sludge buildup?
What can be used to clean the yellowing edges of the headlight cover on a 2013 Kia Sportage?
4How can I adjust the high and low beam headlights inside the car?
5If both the person and the key are inside the car, does the electronic anti-theft indicator on the dashboard still flash normally?
6I've had my car for over half a year, and I've noticed that after driving in the rain, there's fog inside the headlights. It disappears after a couple of days or when it's sunny. The after-sales service said it's a normal phenomenon! Do any fellow car owners have a similar situation?
7Have you noticed water droplets inside some car headlights? What's going on with that?
8Is it normal to feel slight vibrations when sitting inside a Patrol 4.0 at idle?
9Is it normal to have watermarks inside the headlight cover?
10Hey experts, the headlight cover on my Sharan has turned yellow and has lots of small cracks. Can it be repaired, or do I need to replace the cover? Is there any place where I can buy the parts? Thanks.
