نايف آسيا
2024-09-03 13:00
حسين أمين
حسين أمين2024-10-24 08:37
There might be something wrong with your car. Normally, the mileage shown on your car should match the actual mileage in your record book. As for Boyang, Li Chen reminded him that it can be adjusted at the service station.
عمر عَبْدُ الْعَزِيز
عمر عَبْدُ الْعَزِيز2024-09-03 14:33
After maintenance, reset the diagnostic codes.
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
How to reset the maintenance reminder on a car?
To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
How do I reset the trip meter after maintenance on a V40?
I've changed the oil. How do I reset the maintenance reminder?
To reset the oil light on an Acura RDX, follow these steps: 1. Turn the ignition to the "ON" position, but don't start the engine. 2. Use the steering wheel buttons to find the "Settings" menu on the display. 3. Navigate to "Maintenance Info" or "Oil Life" using the arrow buttons. 4. Press and hold the "Reset" or "Select/Reset" button until the oil life resets to 100%. Make sure to consult your vehicle's owner's manual for any model-specific instructions.
How to reset the maintenance reminder icon on the X90 Zilong? Can someone help, please? 🙏
How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
Does your car make a creaking noise on bumpy roads? I took mine to the service center, but they couldn't find anything. Does anyone else have this issue?
JETOUR Jetour X90 Plus
Jetour X90 PlusAED 119,000Gasoline
