Hey car enthusiasts, my car key unlocks and opens the doors just fine, but I can only start the engine if the key is in the cup holder. It won't start from any other spot. What's causing this? #StartEngine #CarKey #JetourX90Plus
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
4The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
5Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
6What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
7Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
8Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
92014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
10The car hasn't been driven for just two days, and the door can't be unlocked. I used the mechanical key to open the door, but there's no power at all inside. What's going on?
