Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
How do I turn off the 360 panoramic image that pops up on the central control when turning?
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
4Does this car have a 360-degree camera?
5Does this car actually have a 360-degree camera system?
6Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
7Does this car have a 360-degree camera system?
8How to set up 360-degree imaging to display when turning left or right?
9The 2017 flagship model has a reverse rearview camera that doesn't tilt down, even though the setting is checked in the car's system.
10When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
