Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
Why does the car show a transmission fault warning during a cold start, but it goes away after waiting and restarting?
Is it normal for the 2021 four-wheel drive to show an icon on the dashboard with the front wheels tilted, or is it a four-wheel drive warning? The dealer says it's normal, but it didn't seem to be there before. 🤦♂️
How is the quality of the 2023 JETOUR X90 ZhuLong Changsheng 7-seater?
4I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
5Is your Jetour X90 Manual Enjoyment 6-seater not showing the oil light on the dashboard during the self-check before starting the engine? Does it remain off even after starting the vehicle? Are you guys experiencing the same issue?
6When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
7Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
8When I start the car, the dashboard shows "Auto Start-Stop Unavailable" and then "Check Engine". What's going on? I just replaced the battery not long ago.
9Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
10Where is the auto start-stop switch for the Jetour X90 PLUS?
